Prop painted with 4 coats of no nonsense zinc followed by satin black
ARB painted with zinc followed by some left over blue I had
I managed to shear a bolt from this -
I managed to still secure it but its still annoying! No idea what its for..think its just there case the prop comes loose and falls down? Or to protect the prop in some way...
Filled the diff with Fuchs Titan Race SYN 5
New rear brake hoses as I got sent the wrong ones..
I then ran into a problem, after bleeding the brakes and getting to a point where its almost ready to drive I couldnt get the passenger side rear hub nut on! :annoyed:
Turns out id damaged the thread so the nut wouldnt pick up the thread...managed to solve this by hours of work..I had to take apart the rear end again so I could get the shaft free to allow me to file a clean taper round the end and clean the thread up -
My neighbour who used to be an engineer has almost every tool you could ever want so he managed to sort it for me..
Although it worked, the other day when I put it back together and put the nut on I ended up damaging the thread again
I kept tightening and loosing the nut to make sure it went on okay but it managed to get real tight at one point and it sheared off part of the thread so it looks like (((|(( kind of..fogot to take a pik..but the nut still goes on and off it manages to go over it..but I feel that was down to luck so Ive put it on tight and in the near future when If I do any work to the back end I will get a new shaft an nut and whack it on for piece of mind :nod:
