Ultimate wheel fitting guide
C
cyris
came across the sickest rims
18x10 +16
18x11.5 +17
31 January 2010
Australia NT
Wheels: 350Z Track wheels
Offset: +30
Tyres: Front 225/40/18 Rear 245/40/18
Spacers: No
Suspension: Stock
Comments: Fronts clear eazy,Rears Scrape on bumps heeps!!!!!!!! But looks sick
V
VAs15
My old setup
Wheels: Volk TE-37
Size: 19x9.5-F 19x10.5-R
Offset: +12
Tyres: F - 215/35/19, R - 235/35/19, Falken FK-452's
Spacers: none
Suspension: Fortune Auto Coils
Comments: Front and Rear fenders were rolled and have a small pull
T
tripleJs15
seen your can a few times in pics, I think on zilvia as well. Looks great.
C
cyris
just pick up a set of rims for the s15
Work VSKF's 5x114.3 18 x 10.5 +0 and 18 x 9.5+14
V
VAs15
running overfenders in the rear?
V
VAs15
i had a 10.5 + 12 in the rear, we spent 2 days doing the fenders and the 10.5 +12 in the rear was cutting it
but good luck
C
cyris
what was your camber in the rear?
V
VAs15
not sure what it dial in but maxed out as far as stock would go
Glen
Vehicle: Nissan S14
Wheels: Work Meister S1 2P
Offset: +20
Tyres: Archilles 18/225/40
Spacers: 13mm slip on up front to clear strut
Suspension: BC Gold Maxed front, Rear 10mm away from lowest.
Comments: Front guards rolled, rear rolled and pulled 15 - 20mm.. Rear can run nearly 0 degrees camber , front is at -2.5, -3 would be ideal for to clear guards.. Front requires less castor in the front left to stop rubbing and maybe higher preload and damper setting to stop it bottoming out.
18 July 2009
Warwickshire, England
Wheels: Sparco racing NSII
Ofsett: +22
Tyres: Falken FK452 225/45/17
Suspension: Driftworks CS2 coilovers, standard arms. -2 front camber, -3 rear camber (stock arms maxed out)
Comments: Rears had the lip rolled flat, and have got about 8-10mm space when the wheel is tucked up into the arch, but will be less when I get rear camber arms to correct it. Front is standard. No scrapes :) Car is moderatley low, pictures to follow
14 June 2010
united kingdom
hi guys im looking at this wheel choice, can people please tell me what exact widths and tyre size i can use without having to roll the arches? Im looking at parada spec 2s and an 18inch rim.
And dont worry about the wheels saying 4x100 as u can get these made to your exact specification (as far as ive been told?)
http://www.rarerims.co.uk/alloys_sub2.asp?id=82
Trial_S15
13 July 2008
Meath, Ireland
www.modifiedmotors.ie
Spec S S15
Spacers: none
Suspension: Driftworks CS2's
Comments: standard arches
Wheels: Work CR Kai
Size: 17x8JJ ET 32 Front and 17x9JJ Rears ET 30
Tyres: Hankook Ventus 215/45r17 front and 225/45r17 rear
Wheels: Work CR Kai
Size: 17x9JJ ET 17 all round
Tyres: Toyo R888 225/45r17 all round
Comments; stripped the front wheel arch liner on the drivers side but no other issues (only used on a clockwise track - not on the road)
Wheels: Nismo GT4
Size: 17x7.5JJ ET 30 Front and 17x8.5JJ Rears ET 40
Tyres: Hankook Ventus 215/45r17 front and 235/45r17 rear
eiden88
7 May 2009
Lecce ,Italy
probably getting my hands on a good set of avs model5:
18x9 et +10
I'm only concerned on how much would they stick out. I'm running oem guards and tein super street. am I going to have any steering issues?
Glen
They wil stick out haha, camber them in! roll and pull.
Hi guys,have found some wheels I really like just not sure if they will fit.they are 18 x 9.5 ET35 all round,I have full set of adjustable arms on the car and tein super streets with pilLo ball top mount,do you reckon these will fit????
They are wheels only so will need tyres too any suggestions on size?
Any info will be grately received
Psychogopher
Wheels: unknown
Ofsett: +35
Tyres: 235/45/17
Suspension: Standard
Comments: Currently running
And I have just got!!
Wheels: Rota GTR
Size: F 18x8.5 R 18x9.5
Ofsett: F +35 R+30
Tyres: F 225/-/18 R 235/-/18
Comments: Not on any tyres at the moment but I was suggested the width by DW. Don't know how critical the aspect on tyre is but was told by ProTyre R 40 and F 35 and sort of told this is BAD :(
front 225/40 and rear 255/35 this is a nice fitment without too much stretch :)
