Neo vvl - p11 cylinder head
After a long time waiting to find a P11 SR20VE VVL Head I finally have it.....
I'd posted earlier in the year that i'd bought one, but the engine importers that accepted my money never came through with the head, so cancelled order and onto the search.
I found a guy selling the head minus the valves and cams but with all the ancilliaries for a realy good price, which was perfect for me as i'm changing the valves, valve guides, valve stem seals and cams.
VVL
My other DET head
Comparison between port on DET and VE head (DET on top)
You can really see the difference in the port size, no port and polish on a DET will get close to the flow rate of a VE
All the bits
Now is the start of the machining and metal treatment works which i've been looking forward to.
Machining
Combustion Chambers CNC machines (Fully Spherical) to 90mm
Head resurface
Multi Angle Valve Job
Port and Polish
R&R Valve Guides
1/2" Head Stud Machining
Metal Treatment (WPC)
Combustion Chambers
Valves (after cut)
Cam Caps
Rocker Arms and Roller Shaft
Valve Springs and retainers
Cams
If you've not heard of WPC before check this links, it's used by a lot of the pro race teams and F1 and it's only available in Japan and California (everything that I can have treated on both head and block will be treated along with surface coatings as needed)
http://www.motoiq.com/magazine_arti...-part-1-all-you-wanted-to-know-about-wpc.aspx
Some more pics soon once I get the rest of the valves etc in.
