Ah 2 weeks and you will be blasting about ! Bit jealous I must admit gonna be awesome man
I dont have the stock fan and shroud setup either (twin electric with shroud), so i had to cut that exact same corner off to accommodate intercooler piping, providing there is a bit of plastic frame that goes around the fan itself it should not lose too much strengthAh yeh, the fan shroud. The fan blades are miles away fortunately, and the amount of air those things shift when they come on I am not worried about losing the corner
I do agree that I could do with a more elegantly welded solution. I'll have the bloke that is welding it chops the right angled corner off and weld in a plate so that it is a bit more of a passageway for the air rather than a box.
Im pretty sure it is all too tight for using any silicone, especially as I have to bump up the diameter of the pipe to 83mm for the throttle body. Fat tubes!
