Ultimate wheel fitting guide
6 May 2009
germany
i mean i dont want to much chamber...
any one knows how much chamber i have to go if i would go for 18x9,75 et 20 at the rear? will this work?
davib
i've read a lot
just want confirmation
te37
17 x 8.5 +30
will they fit with no issue at the front ??
nismo option suspension.
i have a set of these, but left it at my brothers.
was going to try it out, but no time until next year!
opinion ?
rear shold clear no problems'
S15 SILVIA
Is it Nismo s-tune suspension? Standard style setup, not coilovers.
If so, will fit fine, as I have s-tune suspension with 9x18 et 30 all round with no problem on the front. Little rubbing on the rear, but very minor. (need a slight roll to the arches)
depending on what tyres you fit, the rears should fit ok on yours.
Mike
davib
thanks for that!
does 245 fit at the rears without rolling the guards?
1 November 2010
Saint-Petersburg, Russia
Damn! Guys, I hate myself... ;) Cause I bought another set of Volk GT-7 17" 8"/9" )) And 17x9 don't want to fit on front turbo brakes ;( +38 or +43 offset... Need spacers... )
Want to make a set for my car: 17x9 in front and 18x10 in the rear ))
11 December 2011
okinawa
Wheels:ssr professor sp1
Size: 17x10 & 18x10
Offset:-1 ALL AROUND
Tyres: FRONTS NEOVA AD08 REAR FEDERAL 595
Spacers: NONE
Suspension: JIC
Comments:
11 December 2011
okinawa
sorry I dont have anything worthy of what the car will look like in the future, but I have a few pics from when I test fitted the wheels without tires(still crappy pics)
davib
can't wait to see extended fenders and everything ..
11 December 2011
okinawa
looks like i will be running +50mm rears and +40mm fronts. unfortunatly I wont be able to start on the car until around may time frame. But meanwhile Im trying to get an idea of how much work an sr20det engine swap will be. I will try and find one out of a s14 and pull the harness and everything
1 November 2010
Hello dude!
With such big plans I'm strongly recomend you to swap not sr20det, but 2jz-gte with 2 turbos ;) a friend of me got the same kit in his s14 zenki... it gives him 620 bhp, 760 Hm from 3000 rpm...
And by the way, if you ready to give your car a special look, try make front and rear fenders with carbon fiber, not frp ;)
I'm going to make a carbon copy of my TopSecret s15 Wide Bodykit
davib
hi guys
quick question
I'm running 225/45 all round
for some reason i think its scrubbing at the rear
or is it just my imagination ?
I'm monitoring it now
but i see heaps of people running 225...
mind you i don't have rolled guards?
It has more to do with rim width and offset than tyre size. I run 265's on the back of my car and it doesn't scrub at all. The arches have been rolled slightly, but even if they were not rolled, it woudln't be a problem.
Also please refer to my signature about text speak.
11 December 2011
okinawa
@kosoku. Hmm you just put a lil birdy in my ear. Im researching swap kits now. As for the motor and transmission it should be easy for me to get my hands on here.
11 December 2011
okinawa
Another note, I found the +40mm fronts for under 225usd and the rear +50mm for 200usd(frp). Perhaps carbon fiber is out on my price range.
S15 SILVIA
What wheel specs and sizes are you running meddler?
Know wheel offsets etc can make a huge difference, but surely it's a tight squeeze fitting 265 on the rear with standard arches. What suspension you running?
Thanks mike
From memory they are 19x8.5 +45 (I am pretty sure they are +45, if not they are +35). -1.75deg camber with 265/30/19 tyres. No spacers are used on the rear but guards are rolled slightly. Stock brakes with Tein Superstreet suspension and fully adjustable arms. I am not running super low but there is a good picture of me on the track with one of the rears disappearing up into the guard while I was cornering.
E
EXIGE_GT
Is anyone running with 18x9.5 +22 ?
Ive got rolled gaurds and Tein coilovers ...
Was thinking the rear would be ok just the front i might have to go with 20mm wide guards ?
What tyre size would be best ?
Thanks for the help :)
