looking good mate! you're putting a lot of work into her!! it'll be well worth it though
Calipers are easy to paint:thumbs: and whilst you disks are off attack the mating surfaces of the hub, disk(bothsides) and wheel with that metal scrubbing fitting for your drill, ensures even wear so your hub/disk/wheel are sitting correctly, scuf the disk in a star patten with 60grit. and it will all look at good as the rest, nothing letting you down there:nod:Ive got wire wool and some autosol metal polish to make the exhaust look a bit better. :thumbs:
TBH there is going to be things that let it down anyway, I mean I havent bothered getting new discs or refurbing the calipers so they will look crap, and im sure a few other bits will let me down.
Im only doing all this for piece of mind anyway so I know its not going to fall apart in a few years. In time ill get nice new brakes and coilovers and even a new exhaust at some point, but for now im just glad its rust free :nod:
Precisely!!!Or at least properly underseal the chassis before selling their cars!!
Cheers yeh Im going to try something like this, will use washers instead of wood though.you need the old threaded rod and block of wood trick mate, put the rod through the wood, then the bush, then the housing and then another block of wood the other side. tighten a nut on the rod and it will pull through
Yeh this is due an update but I still need to sort loads of photos out first...How's the work getting on now then? I guess you've had more luck with the bushes since the last update
