Ultimate wheel fitting guide
C
cynicks
Hi Guys,
New here, just hopefully to get some reply, will offset of
F: 8JJ +33 / 17"
R: 9JJ +38 / 17"
work on the S15 with HKS Hypermax ? I had some 18" Taiwanese rim that can't fit, as the front rim spokes can't clear the original calipers.
Will the above clear all the issues ?
Appreciate replies...
B
baynz
Hi guys. I've got standard suspension at the moment and i'm looking to fit new wheels
Front +30 225/45/17
Rear +38 245/45/17.
Judging by previous posts it sounds about right, though i will eventually get Apex gen2 coilovers. Just want your opinion to make sure i've understood this correctly. Thanks, and any advice is appreciated.
Day_Dreamer
Wheels: Desmond Regamaster
Size: F 18X8.5 R 18X9.5
Offset: +35 F&R
Tyres: F 225/40/18 AD07 R 235/40/18 DIREZZA DZ101
Spacers: None
Suspension: K Sports 25mm approx. lowered. -1.5 camber front, -1 camber rear
Comments: Front wheels sitting with no problem, rear guard rolled, stretched tyres, wheels stick out 5mm.
C
cynicks
I've got mine fitted :-
Wheels: Advan AVS
Size: F 17X8 R 17X9
Offset: +32 F / R +35
Tyres: F 215/45/17 hankook R 235/45/17 AD07
Spacers: None
Suspension: HKS Hipermax
Notes : Front wheel just cleared the caliper about 3mm range...is it dangerous ?
Day_Dreamer
Wheels: Advan AVS
Size: F 17X8 R 17X9
Spacers: None
as long as there is no contact with caliper and wheel spoke, it wont matter.
Thought I will put mine here
Wheels: Volks Gram Lights 57F Pro
Size: F 18 x 9 / R 18 x 10
Offset: +24 F / R +34
Tyres: F 225/40/18 nexen / R 235/40/18 ku31
Spacers: None
Suspension: Greddy type-s, cusco rear upper arm, cusco rear toe arms
29 May 2009
ireland
Below are a few of good fitments to show everyone what you can actually fit to the stock guards since everyone is so afraid to run lower offsets on their rides. I made this mistake and is regretting now! However this post is only showing what fits flush(my term of flush is top rim is very near the guards and bottom rim is sticking alittle out) Hope everyone can learn from this post of what you can and cannot fit.
All the cars below are running at stock guards rolled unless specified.
I'm sure some of you have seen ben's (SpecS15) s15. imho his has the best fitting
Wheels spec:
F 9J x 18 Offset +22 -2.5camber Tyres:225/40/18
R 10J x 18 Offset +25 -1.0camber Tyres: 255/35/18
Wheels spec:
F 9J x 17 Offset +28 -3.0camber Tyres: 215/45/17
R 9J x 17 Offset +17 -2.0camber Tyres: 215/40/17
Wheels spec:
F 9J x 18 Offset +24 Tyres: 225/40/18
R 10J x 18 Offset +34 Tyres: 235/40/18
(The front protrudes abit, wider front arches will fix that but I still like it :p)
Wheels spec:
F 8J x 18 Offset +29 Tyres: 235/40/18
R 9J x 18 Offset +32 Tyres: 255/40/18
Wheels spec:
F 9J x 17 Offset +22
R 9.5J x 18 Offset +22
^^Not 100% sure but I reckon that's what it's running
Hope this helps all! Have a good one
can someone give me the size wheels on the white s15 above??as your man not 100% sure,please
Well if you find out, let me know too but it wouldnt be far off... this is another one with similar size/offset
F: 17x9 +15 215 45 17
R: 18x9.5 +12 225 40 18
Camber... according to owner, whatever it takes... guestimate is about -4 to -5
For an s15, personally i would go below:
F: 17 x 9 +15
R: 18 x 9.5 +22
29 May 2009
ireland
F: 17 x 9 +15
R: 18 x 9.5 +22
------------would i have problems fitting this size im running coilovers bc sports???????
and would i have to go that much camber -4!!!!!!!!!
d.
24 November 2006
sydney
I am interested in replacing my Enkei RP01s (white) with RP03s (silver) but am unsure of a suitable offset running Nismo S-tune suspension under standard guards.
They are available in the following sizes and offsets:
17 x 7.0 + 45
17 x 8.0 + 40/48
17 x 8.5 + 30/35
17 x 9.0 + 40
I am thinking of:
F: 17 x 8.5 + 35
R: 17 x 9.0 + 40
OR: 17 x 8.5 + 35 all round
Is this the right choice or is there a better combination available?
B
baynz
at present im running ultralite atec 18x8 f and 18x9 r et +35 all round, rolled rear guards, hsd coilovers, 225/40/18 f and 255/35/18 r and have no issues with clearence anywhere, i have plenty of room, and only around 1.5deg neg camber on the rear.
19 January 2009
UK
Recently i was running 17" xd9's 8.5jj front et+25 and 9.5jj rears et +17. Had to fold the lip on the arch up on the rears and maybe 1 or 2 degrees of camber on apex coilovers.
Going to be fitting new works emotion xd9's this weekend all 4 are 18" 10jj et +18 :p
it's going to be fun, tyres are going to be 235/40/18 fronts and 245/40/18 rears.
19 January 2009
UK
F: 17 x 9 +15
R: 18 x 9.5 +22
where did you get those light eyelids or whatever they are called from? love the car and the rotas are lush! looks similiar to the rotas that were on a black fd on dw
19 January 2009
UK
Not my car dude but those are cwest eyelids...
And those are genuine volk racing TE37s... not rota ****
ah thats what rota ripped off was it :rolleyes:
will have a look at these cwest eyelids :0 cheers dude
I'm looking at some Rota Torques as a second track set lol :p
Can anyone confirm whether this will be ok??
17 x 9 +35 (both front and rear)
Thinking 235/45 for both front and rear tyres as well. Standard arches - Tein Super Street coilovers.
Cheers,
J :)
_Wing_
because:
if that's not bad enough then there's plenty of cases of this happening on rotas:
