- 13 November 2005
- Hong Kong
- www.s15oc.com
good work buddy ur doing very well:thumbs:
OK.The engine is in but not running yet. I think (hope) it's the 180SX air flow meter that I thought would be the same as the S14. Apparently it isn't.
I used the M60/F4 plug pinouts, and they were also used by Max and his engine is running now. John Bennett on SXOC has been a great help with regards to the wiring.
:thumbs:Because I don't have one yet. I want it up and running before modding it, otherwise there are too many places to look if it isn't going properly. Having said that the larger bore SR20DE throttle body is fitted too, so hopefully that isn't causing any dramas.
the brake lines are redone (now I've removed the ABS unit), QUOTE]
Mitch, What was process involving removing abs unit? I want to ditch mine. Not sure where to start.
