Right, some updates, Rainer finished all my intercooler pipework today, cuffed to say the least, one complete piece hot side, one complete piece cold side, to help minimise boost leeks etc, so only 4 joiners! And the pipe come on and off the car easierly:
Every end is swage'd too, accept the one into the throttle that is a welded band.
There's also now no room for my oil cooler in the drivers front wing.
But after talks with my mate it really doesn't seem a good idea anyway. He pointed out that if I go off on track and hit gravel (we all know how unforgiving that can be) if it rips my bumper... High chance it could take the cooler with it... Which could potentially be bye bye engine!
So will all that in mind.. I'm going to make room for it between the intercooler/fans and rad.
Also the car now has a fully working handbrake (will be better one pads wear in mind) and the missing bleed nipple showed up today, so all my brakes are now bleed!
Rear propshaft was sent off for making on Wednesday.
Rear wheels are done, I had tyres fitted the other day:
Bare in mind these are 12J WIDE! Was pretty happy with the fitment:
I know the picture qaulity isn't amazing but gives you an idea, they look spot on in the flesh, spent a good hour setting the ride height/camber and toe on Tuesday, just buy eye, and measurements, I know it'll need professionally doing but atleast it gives them something to work with rather then being a million miles away.
Only one real bit of fabrication left now.. Last minute changes where decided last night..
My fuel is going to be cut apart... Two baffle plates welded in, and a false floor slanting down towards the pickup point. I have also Order'd a ATL fuel probe which will be fitted at the same time.
At the moment the tank is just flat and empty with a 1inch foam floor... Wanted to baffle it to help with weight shifting when cornering hard, as no one likes a sloshy tank! And the False sloping floor to help with it starts running low.
That's all for now, still waiting on engine, really hoping its back soon so I can finish this!
