Please let me explain...Not exactly true because I am taking the rear of the Z32 casing and putting it on the RB25 bellhousing with RB25 internals and using Mazworx's short shifter kit for the Z32 rear casing means I wont need to trim any of the shifter housing where it comes through on the standerd 6 speed as their kit makes it come through at the same angle, I have been told this will work by one of the leading guys in the UK as he has done this before but will keep an up date on my members thread of how it goes
The facts so far...
- You know that the rb25 and z32 gearboxes are basically the same internally, which means the major differences are external, IE their housings.
- You also know that the rb25 and the z32 bellhousings / front housings are basically the same in length, and the housings can be interchanged freely with no modifications, therefore swapping bellhousings around is pointless for us as it will not change the shifter position.
So at this point, for the scope of this discussion, everything at the front of the gearboxes are basically the same.
You now know that the major difference is the rear housings - the rb25 rear housing where the shifter sits is TOO SHORT, whilst the z32 rear housing where the shifter sits is TOO LONG, therefore the shifter position is determined by the rear housing.
IE
Z32 rear = TOO LONG = shifter sits behind your shifter hole
RB25 rear = TOO SHORT = shifter sits in front your shifter hole
So.....
- If you swap a z32 rear housing onto a rb25 gearbox, then you have a gearbox with a shifter that is TOO LONG because, as you know, the z32 rear housing determines the shifter position.
- And likewise, if you swap a rb25 rear housing onto a z32 gearbox, then you have a gearbox with a shifter that is TOO SHORT because, as you know, the rb25 rear housing determines the shifter position.
I hope I make sense and hope that is helpful.
The shifter position solution that we at ALPHA OMEGA Parts and Services has came up with is to manufacture parts that will bring the z32 shifter position back into the standard shifter hole - this is another reason why we chose the z32 gearbox because the shifter design allows us to get the shifter in the shifter hole (and the rb25 shifter design does not)
