Yay, good news
If you can craig this would be great.When the panel is made, the parts that need to be cut out are rough and slightly sunken into the coating so it's obvious where to cut. As your only down the road I'll show you one that hasn't been cut (when I have one) so you can see what I mean and decide what to do. It'd be a shame to have the holes if you don't have a bonnet catch![]()
Same boat as you mate, as craig has pointed out above the hole for the bonnet catch can be left uncut althought the finish around this area may be a bit rough. The hook on the hood would require grinding off i would assumeI only need the hole for the hook in the hood.
The hood lock is removed´cause I installed aerocatch locks.
