Hypnotik S15
13 June 2010
Pisa, Italy
www.flickr.com
Hypnotik 425whp S15
This is my car, it was basically stock when I got except for a RS*R exhaust, some ugly wheels, and a crappy FMIC. The car was originally a Spec S but it's been swapped to a S15 SR20DET and a S14 5-speed.
Here's what the car has now, all of this was done by myself in the last couple months.
Engine
-S15 SR20DET
-S14 5-speed transmission(Z32 once I get the adapter)
-Apexi Power FC L-jetro
-FD3S 850cc injectors(cleaned and flowed by Witchhunter Performance)
-Forced Performance TD06SL2 20G w/ 8cm2 housing
-AEM Methanol injection kit with 315cc injector
-NGK BKR8EIX plugs
-Tomei 256 cams
-Circuit Sports rocker arm stoppers
-VCT eliminated
-Tubular exhaust manifold
-S-tec Performance turbine outlet
-KTS intake hardpipe
-Z32 AFM
-Koyo 2-core copper radiator
-Circuit sports silicone radiator hoses
-4" intercooler core and custom piping
-ACT Sprung 6-puck w/ Extreme pressure plate
-KTS 13/16" clutch slave cylinder
-Exedy clutch master cylinder w/ stainless clutch line
-Touge Factory injector collars
-SR20DE 60mm throttle body
-3" downpipe/decat/cat-back
-Blitz intake
Suspension
-Tein Type FLEX coilovers
-Cusco front tension rods
-Circuit Sports tie rod ends
-Powered by MAX tie rods
-Energy Suspension steering rack bushings
-Wicked Tuning rear toe arms
-Cusco rear camber arms
-Energy Suspension sway bar bushings/endlink bushings
-Creative Steel motor mounts
-Peak Performance "Race" transmission mount
-rear subframe spacers
-front/rear strut tower bars
-Nismo GT Pro 2-way LSD(adjustable initial torque)
-Alignment by Myself
Brakes
-Front - Evo IX Brembos
Hawk HP Plus pads
SPL Performance braided stainless lines
Touge Factory adapter brackets
-Rear - Skyline R33 2-pot calipers and rotors
Hawk HP+ pads
Wheels
Liquid Metal Motorsports F5's
-18x9.5 +20 at all four corners
CST Zero-1 Hypers in the mail
-18x9.5 +15
Tires
-Nitto 555 235/40-18's
Misc/Other
-MOMO Race steering wheel w/ 30mm spacer
-Defi boost gauge
-AEM UEGO wideband
-Spec R A-pillar pod
-12000K HID kit
-Pioneer HU
-Alpine Type-E speakers
-Kicker 10" sub in ported box tuned to 40hz
-Rockford Fosgate amp
When I got it
Now
The new turbo, TD06-20G
Wideband fits like a glove
New tie rods
Energy suspension steering rack bushings
Moved :)
Looking good mate. I like the night time pic too, looks really good.
5 March 2009
qld,australia
yeah very tuff. It looks and sounds the business inside and out. Pewter as well :thumbs:
13 June 2010
Pisa, Italy
www.flickr.com
Some new pictures, I had it detailed and clay bar'd yesterday. I also put the stock hood back on, the fiberglass one was just really poor quality.
Trinidad
Very nice work. Only thing, why is it that you have the BOV on the hot pipe? I know for a better setup the BOV is usually placed on the cold side close to the intake manifold throttle setup so as soon as the throttle flap closes the air is vented immediately rather passing back through the intgercooler and then hitting the compressor blades of the turbo and causing compressor surge and then venting via BOV. Just a thought, car looks nice just need some fender loving for the back and it's good to go.
13 June 2010
Pisa, Italy
www.flickr.com
I'm not all that concerned about the BOV, it's tightened down enough that it never opens anyway unless I'm hitting full boost. I've had it on the hot side on all my cars and I've never had an issue, I don't think it matters much.
Do I see the road under your Air Intake? Bov on hotpipe is common, all you need to do now is re-circ it.... big improvement to my car once i did that.
Looking good, better with the stock bonnet :thumbs:
13 June 2010
Pisa, Italy
www.flickr.com
My new transmission. Z32 TT 5-speed, I plan on using a Mazworx adapter kit.
My new brakes, got these in the mail last week. I just waiting on my high temp decals and my brake lines from SPL Performance.
After paint and assembling.
Trinidad
Sweet brakes look mint, I am waiting on my rear R34 brembos to install, I am currently running crossdrilled R33 units, no doubt stopping will not be a problem either.
B
bounceae86
Very nice indeed !!!
I'll be interested to see how you get your speedo working that's my problem at the moment with the 14 box
Trinidad
Should not be a problem as the S15 takes the spee from the rear diff sensor not the box.
13 June 2010
Pisa, Italy
www.flickr.com
Looks a lot better with he stock bonnet on,man :thumbs:
What rear lip/spoiler is that?
I was under the impression that it was the Nismo ducktail spoiler. Is it not?
My speedo works perfectly. Well, almost perfect, it's a little off because of tire size.
