hi all,
i dont really have much time to spend for the time being. just enought to login & post some required materials regarding my stolen S15 Spec R. As i have problem to login to DCM, i appreciate if anybody can somehow link/copy this thread to DCM as well as zerotohundred.com, angle-D5, feinto-D, facebook, etc.
here are the details:
Spec: Silvia S15 Spec R
color: yellow with RACECRAFT carbon fibre hood. original paint is black if bodykit is taken out, with rear original fender arched to make way for crazy offset rims.
bodykit: full bodykit from VIVAGARAGE 70mm wide fender (rear/front), only 1 in Malaysia/South East Asia. very similar to BN SPORT BLISTER
wheels: front; (two) SSR AGLE STRUSS, 5 holes 114.3, 17x9j +11 offset wrap with YOKOHAMA AD07 235X45X17, rear; (two) WORK rims 5 holes 114.3, 18x10j -10 offset (roughly). 2x 1.5inch thick front spacer, 4x 10mm rear spacer
steering: KTS leather type 3 spoke deep dish with carbon look ring (blue horn cap)
bosskit: Rapfix (japan) (black color)
harness: TAKATA 6 points (green)
turbo time: APEXI pentimer (black)
boost controller: HKS EVC 3 (black)
boost meter: OEM side pillar boost meter
seat: full bucket PRODRIVE by Sparco (driver) with seat railing (japan), OEM (passenger), (no rear seat/removed)
gear knob: NISMO carbon look 10mm
shift boot: Carbon look shifboot (japan)
ICE: PIONEER (silver)
radiator: M&H two layer aluminum 40mm (only 1 in Malaysia/South East Asia), with BLITZ (blue) radiator cap
oil cap: NISMO (crown) oil filler cap
oil cooler: universal M&H 15 row (blue) -10AN fittings, 2x1600mm length braided line, 1 pc oil adaptor 2x-10AN fittings (only 1 in Malaysia/South East Asia)
wastegate: M&H 38mm (black) 2 bolt external (only 1 in Malaysia/South East Asia)
exhaust manifold: low mount DC SPORT extractor (USA), original low mount DC SPORT extractor is without wastgate flange!!! mine are modified to fit external wastgate!!!
turbo: HYPERGEAR ATR28G3 T2x flange A/R.64 (only 1 in Malaysia/South East Asia)
outlet pipe: M&H twin exhaust outlet (only 1 in Malaysia/South East Asia)
engine damper: T's RACING (Japan) (red color) (only 1 in Malaysia)
fuel regulator: AEM + adaptor/joint
fuel pump: WALBRO
injector: 4x SARD 850cc
fuel cap: NISMO fuel filler cap
air filter: AEM 6"x5"
intercooler: GREDDY SPEC M intercooler kit with SAMCO hoses (blue)
ECU: HALTECH E8
suspensions: KTS ALPHA TYPE (blue) front/rear
arm system: KTS PILLOW BALL TENSION ROD, KTS TIE ROD, KTS TRACTION ROD, KTS REAR UPPER ARM, KTS REAR TOE ADJUSTABLE, KTS REAR MEMBER RIGID SPACER (all of these in blue KTS theme color)
tower bar: CUSCO front & rear (Silver bar with blue end)
brakes: front; GTR33 4 pots. rear; R32GTST 2 pots rear brake set
those with "only 1 in Malaysia/South East Asia" is definitely only me & me & me & no other people in Malaysia or any other South East Asia country using it/ have it. i am the only one who brought it in. if anybody happen to see these items, its definitely stolen from my car!
i will post pictures of my car together with parts & accessories when time permits.
