loads of places mate. The s14 filter is identical. You can order a box from perfect run. I use the sard magnetic filters they last for 10k kms before they require changing.
Bro,I had Mobil 1 Fully Syn 5W50 in my car (because it was 26% discounted at Carrefores). I wanted to take it up to 10,000km or 1 year. But after 7 months (5,000km), the oil was mat black most probably due to running rich (as you all know by now from the pics of my plugs in my other thread). So my thinking would be more towards using semi-syn and run up to 5000km or 6 months instead.
I totally agree about Motul...probably they only are <5% better than other reputable brands...i feel they are overhyped and not worth the premium...as long you use a good quality oil from a reputable brand, i guess there should not be a issue...Its your engine la bro. Change to vx rom and you'ii be sorted. I usually change about 5000kms and when change its still golden black color. Elf is damn good as well. Whatever you do stay away from Motul. They're horribly overprcied and not worth the time.
I had something similar in there mate the week before which my mum can get for trade price. Just that my sump plug (APEX magnetic sump plug) thread broke in the sump hole when i tightened it up after draining out some oil and ended up dumping the whole lot. So i just popped round the corner and brought it from there as i needed the car running as i was supposed to be leaving for JAE.i was gonna go for the comma mate, theres a jayar components round near my work - by the way if thats what your using then why not get the planet 5w40, its only 18 quid and its the comma oil in thier own branded bottle! only reason i went for the millers is because it was only 4 quid more and has a slightly higher spec through the additives - thats it.
im still stuck as to the fill mark on the dipstick though, any ideas?
The first number is the low temperature rating and the second number is the high temperature rating.(Sorry for bumping an old thread, better than starting a new one right?)
I've read this thread and was just wondering what the difference was between the 5W40, 10W50 etc. was?
I have a Spec R turbo S15 and its due for a service, just getting an idea of which oils and what quantities I should go with.
