Yakozan's JDM Spec-R
S1Five
just go change it to the ap racing caliper ones =D
save the hassle of re-painting them hehe
hmm i wonder wot rims should i get later on for my track rims with semi slicks!!
You're going to love those collars :nod: Can't believe the difference it makes to the back end... :eek:
The rear C collars are a bit of a b@stard to slide in though...
You fitted yours then?
No more wobly wobly on fast cornering?
How about the noise?
I can't hear a fooking thing over the clutch! :p
I can hear a noticeable clunking from the LSD now. Nothing bad. Cornering is razor sharp now :nod: Could have been that my bushes are quite tired anyway...
I still dont see what difference the collars make :no:
Wheels look good though, changed your rear lights?
Skyline looks pants with those wheels on :p
p.s. S15 Just needs a spoiler now :thumbs:
In my head the collars lock around the bushes and leave them with less room to flex because the collars is in the way :)
Don't know if it works in real life, but many people seem to rate them high.
Same rear lights. Just removed the tinting.
If I ever got a spoiler on my car it would have to be a Yashio factory carbon trunk. That thing looks ace :)
It's been awhile since I last updated. well to be honest. I haven't done much to the car. But just started to fir my oil cooler. Now I'm only waiting for the thermo I ordered from driftworks. was out of stock with their supplier so might take another week or so.
This is my layout of the oil cooler and thermo installation.
It's a pretty expensive layout. But not as expensive as getting a big branded name with a similar setup. Those would be easier to fit though.
Darn. the Greddy sender doesn't fit in the relocation plate :(
So I will have to put it in the sump.
Does anyone know where I can get a pre-drilled and pre-threaded sump bolt to fit a sender through?
Or does anyone have another idea where to put the sender?
Still no sign of the thermo :(
Will pick up some exterior bits this weekend :)
Nissan OEM aero front and sideskirts :D
After that's painted and fitted and the oil cooler is connected I can finally start to get it MOT ready. Hopefully it will be out on the roads again in a couple of weeks.
Good work mate, your getting the rear spats and more importantly the Aero Spolier :)thumbs:)??
As for the sump bolt, i'm sure our freinds over at Driftworks would know the answer.
Will get rear spats later. No wing. Might get that OEM duck tail wing later on though.
If I get rich, I'll get the carbon trunk from yashio Factory with built in duck-tail :D
Alrighty then, Aero front and sideskirts is now in my bedroom :)
I got them complete with mesh and fog-lights. So now I have 2 sets of foggies.
The front-bar will bolt on.
But the sideskirts might need some work to fit.
I'll start a new thread about that.
