Peglio's vertex edge edition
Better not be ha ha and if they are I’m joyriding it anyway should be able to collect it next week if my gasket turns up . Hopefully be on the road next year
With engine collection being imminent I decided to spend half a day on the car !
Got the rear quarters pretty close now , just a bit of sharpening up to do .
All that’s left is to make the skirts and rear bumper wider to meet the additional width of the quarters , shouldn’t take long !
Hoping to get some paint on her over Xmas
1 June 2019
Dorset
I have just spent multiple hours reading through this whole thread from the beginning, what a journey
The car is amazing man!! Would love to bring mine to you at some point, needs all sorts doing haha
Ha ha has been one hell of a journey man! Thank you ! Glad you enjoyed the read . Should be getting my engine this week , at long last , so will start properly cracking on with the rest ! Planning to take a week off over xmas to get her painted ... can’t wait ! Been a very long time building what I hope is the perfect Silvia
You should mate ! Even if you wanted to pop over for a chat we will be having meets /gatherings in the new year can come and see what we are about
I believe this is the final engine spec
Nissan engine gasket kit
Power enterprise head gasket
Carrillo super A beam
Carrillo Carr bolts
Greddy adjustable vernier pulley
protuner custom cams sr20vet thermostat
cp forged sr20vet 89.5mm pistons
cp uprated wrist pins
nissan oil pump sr16ve n1
arp head bolts 1/2"
supertech valve stem oil seals
supertech oem uprated valves
supertech valve guides
nissan spigot bearing
engine bearings acl race
supertech double valve springs vvl
coolant temp sensor ntk
darton sleeves bored to 89.5mm
new nissan main bolts
ati crank damper
Naprec strengthened timing chain
Taarks billet oil pick up
Taarks billet manual chain tensioner
Taarks oil block
Mazworx solenoid relocation block
Mazworx washer dress up kit
Mazworx threaded front oil squirter
Tomei baffled sump
sr20det to 350z gearbox adapter plate
additional machine work for main saddle oil system modification
Clutch and crank pulley balanced
Engine balanced
Coolant temp sensor relocated
Balanced and polished crank ( late model oversized bearings )
Valves deshrouded, squish area cnc removed .
Cnc cylinder head machining for 89.5mm pistons
Did a bit more on the car today , got the engine sitting right and test fitted the turbo and inlet . Defo going to need to rework my tub as I expected , not bad though just a minor tweak !
Quarters and panel repairs pretty much done now so hopefully be getting the shell and final panels in primer soon
Managed to make some time for silv today .
Got the doors boot and shell into spray filler ! Only the rear bumper to go now , be nice to crack on and lay some epoxy and high build next ready for some paint at long last !
Decided to go in on a Sunday to fit it all back up as I couldn’t wait to see the car pretty much all one colour for the first time in ages
Had a little time on the old girl today .
Going to crack on getting the bay ready for paint now
Had to chop my tub to make some space for my turbo ha ha ha just so I could rotate the housing more and have the outlet going at a similar angle to the tub in order for the pipe works to run parallel to the chassis leg up to the intercooler . who wouldn’t make their car fit their turbo eh ha ha
Always have to crack a beer after a day on the old girl ha ha few and far between
Will be getting on prepping and smoothing the rest of the bay now so hopefully be in primer soon then can finally start getting some colour on
Amazing work as always Chris :notworthy:
Cheers mate !
Pretty happy with how it’s come out ! Shame to have had to do it but will make a nice feature ,
Considering using some of the gold heat film in that part to contrast against the gold paint
