You'll have to ignore RR figures, I've rarely seen anywhere that gives accurate readings. I see 400bhp cars posted by people on GT2871R's running 1.2 bar... I don't think so, lol. You'll have to run fairly high boost to get a legit 380bhp out of a GT2871R (I'm talking about 1.7bar) or cams aswell with a lower boost level. The stock head on the SR is quite poo to be frank
Clutch wise, I used an Exedy Hyper single, and that coped nearly 40k miles at the power levels I ran between and the previous owner. ACT are fairly good clutches, I ran one in my Evo at 552bhp. Not too sure on XTD, I've got no experience with them. ORC do a good single plate clutch kit, like the Exedy too that'll handle 400bhp too.
The actuator on the GT2871R is a bent arm if you get the man sized version
(the .60a/r that uses traditional hose fittings on the intake and outlet of the comp cover). Otherwise you can run the stock actuator HKS jobby on the version that uses the original Nissan comp housing.
