- 14 November 2005
- Age
- 40
- Stockholm, Sweden
- www.s15oc.com
What is that?Nicely said:The brake bleeding is the biggest PITA. The pedal was so bad initially that I've taken the Z32 BMC off to fit a piston kit. Fitted the old BMC back, and now I'm not sure the seals were gone. There's pressure, but right at the bottom. With the Z32, I'd bled, bled, rebled and put it in to get a proper vacuum bled done. Exactly the same.
Apparently, a number of people have had this probably initially and it took a number of bleeds and runs to get the air out. I'd even followed the correct BMC fitting proceedure in the manual...
I've just bought one of these off EGay. Should make it a bit easier for future bleeding.
vaccum bleeder?
I have 2 sets of speed bleeders at home. S15 compatible
