Wheel Size
2 March 2025
New Mexico
I have a few things that I want to do on the new to me S15. Car currently has coilovers, over fenders front and rear, what seem to be R32 wheels and 205/55R16 tires. The wheel offset seems to fit well with the arches but looking for a wider wheel and tire. 205's are not handling the power well, spinning the rears through 3rd.
Any suggestions on offset and tire size to get more rubber on the ground?
-Rob
2 March 2025
New Mexico
So looking a bit into this I'm thinking 18x9.5 ET30 with 235/35 front and 255/35 rear tires would put me close to where I am now with outside fender spacing. Looking at lifting the coils up a bit so rubbing would likely not be an issue with the wider tires I'm assuming.
This offset will push the outside of the wheel out about 4mm (0.75"), which I think would be fine, but I could probably push them out further.
Just need to measure inside to the coils.
2 March 2025
New Mexico
After some more looking I think I'm settling on silver Enkei RPF1's with the following spacing:
Front - 18x8.5 ET30 235/35
Rear - 18x9.5 ET38 255/35
2 March 2025
New Mexico
Well, looking a bit closer I have around 1" spacers on all four corners with the R32 wheel that are currently installed. Looks like I will actually be around 0 offset on all four corners. Need to pull the spacers off and measure to be sure. I will probably have the ability to fit much larger tires and wheels in the wells.
This site seems to be pretty dead...
