- 13 November 2005
- Hong Kong
- www.s15oc.com
yes indeed thought it was about time u poped over and had a look hehe...do ya miss the S15 then..
CheersTopper said:OMG!!!! , your car is gorgeous!!!!
Really like that alot, good work man :thumbs:, thanks for the contact for the centre console, wanted one of them for a while now
What offset are your wheels?
Not sure how low yours is, but mine has 10cm ground clearance to the kit, and about 6cm ground clearance for the exhaustTopper said:These wheels offsets really freek me out, i fitted 8j ET35 to the fronts, the rubbed on the strut so fitted a 5mm spacer, making it an ET30, its very close to sticking out past the arch. If i raised my car about 20mm the tyre would have missed the spring seat and could fit something like you have, so i guess my car must just be a little to low.
My car has the same ground clearance from the front bumper, Not sure if my bumper is as deep as yours and i'm running little 17'sVERY said:Not sure how low yours is, but mine has 10cm ground clearance to the kit, and about 6cm ground clearance for the exhaust
Yes I do and with summer on the horizon it would have been nice.sushiming said:yes indeed thought it was about time u poped over and had a look hehe...do ya miss the S15 then..
have you checked "the ultimate wheels fitting therad"?Hey,
If you could find out the exact offset on the rear, that'd be really helpful as I'm in the market for a set of RAYS at the moment.
laze.
