- 26 October 2005
- Helsinki, Finland
- www.jull.net
If it was boost cut, why does boost surge up to 1.3+ bar in 6th when it passes through the hesitation if I don't back off?
Having run and tuned two SR20DET engines for three years, I'm fully aware of what boost/fuel cut feels like, having peeled my head off the windscreen many times after hitting it. It won't hit cut until somewhere around 1.3 bar in the current sub 10 degree UK climate and with the existing fuel and air ratio setup. I have an Emanage fitted, so could raise the cut limit if I wanted, however, I see it as a warning and heed it.
The hesitation I'm detecting is just that. You can feel it during boost and the boost continues after it.
All hoses clamps have been checked. Wastegate opens and shuts fine. Controller ruled out. Actuator ruled out. The only thing which hasn't been checked, as far as I know, is the cooler itself. Think I'm going to have to pressure test...
