S15 with an SR22VET
mint
18 March 2007
Asakusa, Tokyo
www.JDMtas.com
tbh Rolling roads all usually crap. Take this car to 5 different rollers in one day and i would bet my s15 on it they results would all diff big time.
Im unsure on this project.. So, Its a 2.2 Litre Turbo. Well an SR20 bottom end with an SR22 head from a Primera?.. Which was NOT RWD or Turbo'd? And with all this tomei parts and snail etc its produced 390hp which is 140hp over a standard SR20det? That dosnt to me seem a savage amount more for the sure amount of money and time thats been put into this.........? maybe im wrong. It looks nice tho.
Baulkham Hills, Sydney
so you've seen the graph and you don't thinks its impressive??????
joc469@nissansilvia.com said:
This was the first run of the motor. We identified a problem with the external wastegate, so next time around we'll have better boost control, another 1/2 bar, and another 1000rpm to play with
Lets not understate this, as said in his write up its a SR20VE head with a SR22DET bottom end, a lot different to " Well an SR20 bottom end with an SR22 head from a Primera"
Its 403.1HP at the rear wheels The stock SR20 unit puts out 250HP at the flywheel.
That would equate to, approximatly from memory, 174HP at the wheels, so it has almost 230hp more than stock. I think thats quite impressive :thumbs:
My S15 when it was standard put out 115kw at the wheels which equates to approximately 154hp at the wheels, so 400hp (300kw) at the wheels is pretty good I reckon.
you also have to remember that the turbo on Joc's car is a bit too small for the head etc. He could quite easily whack a larger turbo on and go for huge numbers if he wanted to, but he wants to drive it to work everyday.
