eiden88
I'm in the process of doing the same swap... :thumbs:Hey
I finally got my spec R swap fitted into my spec S.
But when I turned the key it wouldn't start. Starter works fine and I got oil pressure.
It turned out that I have no fuel and no spark.
So i wondered if there are any fuses or relays that need to be placed in order to make it work, as it might differ from the spec s?
From what you've said it might as well be a couple of worn fuses as ignition and fuel pump are on two different harnesses (as you surely know) so I'd give it a try with replacing fuel pump and ignition fuses
Did you buy and connect the OEM boost solenoid? I'm not sure wether the ECU needs it or not to work properly (i.e. throws a code or runs badly)
Cheers
