S15R
i think its for the auto,a switch Sports and Econ
haha ok, nice little modelNicely said:Its got a light?silvias15 said:Nicely said:Think I've got one of those, but its black. Startlingly good photos BTW...![]()
This reminded me of the mystery connector I keep seeing under the centre console:
That looks like the connector for the ashtray light. Does your ashtray light work?Honestly don't know. My ashtray is permanently sealed shut by having that mini S15 blu-taked on it...
Had nothing to do in the garage tonight so ripped the whole centre console out and had a look.silvias15 said:haha ok, nice little modelNicely said:Its got a light?silvias15 said:Nicely said:Think I've got one of those, but its black. Startlingly good photos BTW...![]()
. nah i'm pretty sure it's the connection for ashtray light. I had to disconnect it when i removed the whole centre console to spray a clear coat over it.
Hmmm, that's strange indeed. The only connection I have (which looks like that plug) under the centre console is for the astray light. No spare / unused plugs lying around. Mine's an Aust. Spec. Maybe only Jap Specs have them?Had nothing to do in the garage tonight so ripped the whole centre console out and had a look.
That connector is not for the ashtray light. The ashtray light connector is smaller and hopefullt connected to the ashtray light
The musterious connection isn't connected to anything on my car either. Could be extra weight to get the car balance perfect![]()
Could besilvias15 said:Hmmm, that's strange indeed. The only connection I have (which looks like that plug) under the centre console is for the astray light. No spare / unused plugs lying around. Mine's an Aust. Spec. Maybe only Jap Specs have them?![]()
Tried this, that isnt it :no:Nicely said:I have a suspicion that the flapping noise when you shut the door is to do with the airbag circuit. Check if it does it when you just press the interior light door switch...
There is a Air duct pipe connected to this and the Sensor, Does it actually work or do anything?Nicely said:Welcome :wave:
Yes, the temp sensor for the JDM climate control lurks behind it.![]()
you sprayed a clear coat over your centre console?silvias15 said:haha ok, nice little model. nah i'm pretty sure it's the connection for ashtray light. I had to disconnect it when i removed the whole centre console to spray a clear coat over it.
Yeh it helps A LOT. I could almost say it's scratch resistant now, almost.khoala said:you sprayed a clear coat over your centre console?silvias15 said:haha ok, nice little model. nah i'm pretty sure it's the connection for ashtray light. I had to disconnect it when i removed the whole centre console to spray a clear coat over it.
does it help reduce the wear?
mines pretty hacked up!
Just had a look at the can i used and it's acylic lacquer. I did about 5-7 coats.Nicely said:Just ordinary lacquer?
Was checking this out with Blinx and Kango on Saturday. Its a one way flap to release cabin pressure when shutting doors.Chris S15 said:rear right: found it. Interesting. I don't think it's for venting the cabin (could be wrong) because when i was look at the back of my car someone was opening and closing my drivers door. Everytime they closed it, i could hear a "flap". Sounded like a one way rubber seal. try it out and tell me if you guys hear it too. But, mind you, i didn't know about that rear right thing, might be it.
