Nicely's Spec R Aero
Lol, you should see our neighborhood a couple of years ago. The Swedish DVLA had this test where every houseowner could buy their own speed bump outside their house for a small fee. There was one road in perticular which had a speedbump every 20-30meter or so. They had to remove it later because emergency services couldn't drive there. :rolleyes:
Jordan
lol.. the industrial estate where i work is like that.... think there around 100 speed bumps possibly more :eek:
You can see where the exhaust hits the floor too :D
Get Air bag suspension, so you can just raise it for bumps ...
that's a bit OTT Topper :)
I was more thinking about the same height as LKdrifters S15s.
that's spot on :thumbs:
Thought you might like this photo. Parked in my bay at work... :D
PhilV
ha ha no way! thats quality ha ha
Derek
Thats cool. What if you drove a Fiat panda would they write panda??
nice set of new pics and thats cool i think i might do it at work aswell lol:rotfl:
Would be good to line up an S13 and S14 in the neighbouring bays... :D
Nice parking bay :thumbs:
Dude, i wish you would wash your car before taking the photos :rolleyes:
If you look very carefully, you can see what was causing my exhaust leak...
:p
I've also fallen victim to the S14/S15 exhaust component inconsistencies Two different S14 turbo elbows/dump pipes, two different lengths :rolleyes: About 1-2cm longer and angled slightly different, so my front pipe bracket wouldn't fit... :rant: Two of the bottom nuts are an absolute fooking PITA to do up on this Trust style elbows :mad: Took ages to get the centre one on the bolt and the gearbox side nut can't be done up with a normal spanner. I landed up doing Yakozan's half spanner trick, except more extreme....
The U-Bute Gearbox-Side Turbo Elbow Bolt Spanner :D
The fitted item
Lol, I recognise that spanner. :D
I did my lower ones from below without to much issues.
The bolt which needs the special spanner is a real PITA though.
It's hard to do tight with such a small one. I ended up fitting something on it for leverage. Can't remember what though. I think it was a ringspanner.
Think that had been cracked a while. Noticeable difference. Think the engine appreciated me fitting some new sparks too :)
