Nicely's Spec R Aero
27 April 2006
Ireland
i like it! Where can i obtain one? my apexi one has no flexi so thinking it might be well worth it to stop the mani etc cracking. Where did you get the turbo elbow gasket (the triangular one?)
O
Oki S15
Does the downpipe touch the body? Mine does and the passenger side can feel it in their feet.
THS Performance. They are sold together. ?130 plus delivery :)
Gasket had been bought previously from Apex. Much better quality than the ones which come with the elbow and pipe. I would only use the flexi-pipe to cat gasket out of that lot. Genuine gaskets for the elbow :nod:
No. Loads of clearance :)
B
baynz
so we would need the s14 nots14a downpipe and elbow for our s15's isnt it?
Yes, but they only sell the S14 type. The S14a is the same so long as both the elbow and front pipe are changed together.
B
baynz
oh yeah sorry just noticed it when i read the write up.
seems a really good bargain. and the downpipe was next on my list so i may invest in 1 soon.
Just bear in mind that you need to rig up something to fit the bracket to the mounting point on the car :) Apart from that, I was quite happy with the quality of it :)
gunner93
Nicely, From the second pic, the down pipe looks very low to the ground. How many inches of clearance the pipe has to the floor?
mitch
That's not a bad price and looks to be pretty good quality from the pics. Would you recommend it to others?
I've had one of their tubular manis on for around two years without issue :) Very quick in sending stuff out too.
Nah, its not that low. The rear box is lower.
mitch
Cheers mate, I think I'll get one for mine. :thumbs:
Is that bracket fitted to the front pipe? I think the only bracket i have is at the joint between the cat and front-pipe
Yeah, its on the pipe. I've reattached the bracket which came with my HKS pipe. That one attaches to the front pipe to cat flange. The pipe bracket sits about an inch adrift of the mounting point. It would be possible to either get the bracket moved along the pipe or get a joiner plate.
8 May 2006
Dublin , Ireland
On the front pipe i previously had the bracket did not reach so had to reuse the orginal bracket that fixes to the cat/front pipe bolts.
I don't do anything major to the S15 these days, but I quite like my latest 'tweak' :)
Finally fitted my Type 2 Apex catch tank, but didn't like the plain hosing (especially near the mani :p ). Thanks to Ben at Hose Solutions for sorting me some braided lines and finishers :thumbs:
The tank is a temporary fit till Apex get their solid intake pipes, then I'll have a bit more room.
Nice.
I had my catch can connected the same way with steel braided hoses and stuff. i bought 2 new threaded auminium spouts though so i could fit those bling red/blue hose ends to the cach tank :)
What size hose is it?
I find AN10 to be very a very tight fit.
They came on with some violence.
You running AN11?
why didnt you reattach the plastic bit to the radiator? wouldn't fit?
8 May 2006
Dublin , Ireland
is there not a carbon canister where that location use to be??
what does the carbon canister do?
It's some :ghey: emissions thingie.
Perfect fit fot a catch tank. I used the canister bracket to fit the catch tank. Just some small modding required :)
Yep, the carbon canister doesn't do a lot.
You running AN11?
Its totally non-EU conforming 5/8 inch :p That's just a tad under 16mm. The spouts on the can and engine are 15mm.
The cowl was a complete PITA when fitting the rad. So I just ripped the fooker out. :D
As I said, I'll be fitting a solid intake pipe at some point soon. When I do, the rest of the bay will get a tidy.
gunner93
Nicely,
I am keen to do the oil filter relocation as its PITA to remove it now. From your pic above, looks like the oil filter mounts has replaced your boost sensor. Where is your boost sensor now? Do you experience lower oil pressure with the longer hoses? Finally, what's the dia of the hoses?
Thanks
