I think its about time i gave this a bit of an update :wack:
Spare gearbox is here for when mine eventually gives up, 46k box and i've just rolled over 47k
Exeddy clutch, pressure plate and release bearing are ready for when the clutch gives up, going to skim the stock flywheel
DW tension rods still need fitting but i'm also thinking of getting DW steering rack spacers
Fitted an Apex oil cooler with filter relocation, great piece of kit
Also now have Autogauge oil pressure and temperature gauges fitted into vents
150mm gearknob fitted, makes it very easy to find gears!
I have a stock bumper which is getting modified to make a bigger mouth, work started on this yesterday, needs a few more hours work to be ready for paint
Also yesterday i got a wire brush out and ground down the rear arches, under the rear end if it looked suspicious and behind the rear bumper. Luckily it looked worse than it was as it was just surface rust
Hats off to the guy i paid to underseal it when i first bought it, its going to take a lot to chew through the amount of primer and underseal he applied underneath so very happy with that and my mind can rest.
Tomorrow should see me taking the front wings and bumper off and doing some rust treatment on the front end, whilst i'm doing this my mate will possibly continue with modifying the spare front bumper
Once the bumper is done and i've finished de-rusting it will get a hit of paint to tidy it up. Theres not much rust at all TBH i just want to be a step in front so hopefully not be long, not a full respray yet but primer arches dont look the best :no:
I'm sure theres some bits i've missed but that will teach me for leaving it so long! Hopefully i'll remember to update a bit more.
