C
cougar power motorsport
Guys iam giving here some info's on the HKS exhaust systems so all, you can compare things . The system has : a) GT extension kit ( elbow of the turbo along with a downpipe ), b ) Hipower 409 catback or Silent Hi409 catback again. So apart from these 2 parts you need either a racing cat or a decat pipe to make a full aftermarket exhaust system from turbo and back .
:thumbs:
- HKS GT Extension kit gives a wider range of performance options on your Silvia/180SX/200SX. Whether you are using stock turbo, GT-SS or GT-RS, maximum performance can be extracted from your turbo with the GT Extension kit
- Extension pipe diameters have been increased for both the main and bypass pipes. Boost response is improved by up to 10% and mid/high RPM power and torque is substantially increased over competitors products during tests at HKS Headquarters in Japan.
- A specially designed dual layout is used for the front pipe. This allows for larger pipe cross sectional area and therefore increased exhaust efficiency. Compared with conventional front pipe designs, the dual layout gives an additional 15-20mm of ground clearance for lowered vehicles.
Model SILVIA / 200SX
Model Code S15, S14
Engine Code SR20DET
Model Year 93/10-02/08
Pipe Dia* (Main) φ65
Pipe Dia* (Bypass) φ50
Pipe Dia* (Front) φ60x2
Part Number 14018-AN001
Retail Price (£+VAT) £565.00
RemarksStock heat insulator must be removed/modified for fitment. Made from SUS304
Engine Code SR20DET
:thumbs:
