- 13 November 2005
- Hong Kong
- www.s15oc.com
see i told u it would be the copper pipe...
Mate,Well I think I found my problem, no wonder it was leaking:
On another note.
Im trying to put my new braided hoses back on but I cannot get the longer of the two coolant lines to go on.
Has anyone else has a problem with this?
Im trying to put it back on so it goes the same way as the original hose did.
But the gap in which it has to go is not big enough as the lock plate still has to fit in the gap yet.
Im lost what I can do as it will not physically all fit unless I bend the end of the hose (really dont want to do this).
I then decided that if I remove the bolt holding on the bracket in the second of my pictures it might fit, which it did, but sadly the hole goes through the housing.
Really stuck, anyone know what I can do... ... ... :annoyed: ??? ???
Thanks for the indication mate...my car is almost touching 50000kmIts just comming up to 50,000 miles mate
It happened after quite a hard drive, but I dont think the age of your car comes into it too much, just get it done asap.
I feel lucky that I caught it before anything more serious happened!!!
Thanks for the tip mate! :wave:I got the hose kit from hose solutions along with new banjo bolts for all the hoses (not the premium ones as it looks like the only difference is you can remove the ends of the hoses?).
But dont bother getting the oil hose banjo bolts as they will not fit the S15 and I had to reuse the original oil banjos after I cleaned them up a bit.
While it was off I also replaced all 4 turbo gaskets, exhaust manifold gasket, all hose washers, wrapped the turbo elbow, and put brass nuts on the turbo to manifold and turbo to turbo-elbow.
It looked liked my engine was on fire when I started the car up becasue of all the WD40 burning off :rotfl:
Hi Nicely,Sounds like the copper washer has been pinched whilst it was tightened. Very easy to do...
Hi Nicely,Was just trying to remember. The oil feed screws into the block rather than uses a banjo connection, doesn't it? Do you know where its leaking? If its from the actual screw connection, take it out and clean it up, then wrap a few layers of PTFE tape around the thread and re-insert.
