HID
14 April 2012
Northampton
Might seem a bit pointless as I've got the factory HID's but can you put a kit in instead? The brightness isnt a problem it's the crisp clear blue tinge light I'm after, also are there any decent LED or HID sidelight options?
If you want a different hue, just change the bulbs for a higher Kelvin rating.
14 April 2012
Northampton
bulbs easily interchangable then, not like HID Kits where the bulbs are connected with no release?
It's like changing bulbs on a regular headlight. Stock HID is D2S 4300K. You probobly want something around 6000K or maybe higher.
Nickichi
13 March 2010
Southampton, UK
forum.s15oc.com
unless you really want blue keep it at 6000k, its the same temperature as daylight so you see more detail in the illuminated area then above or below at like 4300k and 8000k even though the lamp has the same lumen output
29 April 2009
More colour = less light. Something to be aware of
14 April 2012
Northampton
yeah that is true, I need to find a way of clearing up my headlights a lot better, not clearer but something that'll last longer, I'll find some 8K bulbs as thats what i used to have on my ep2 and no problems with getting pulled and had enough light for me, hopefully they will do the trick for what I'm looking for :)
24 November 2009
North Yorkshire
I've got 6000k fitted to mine and thats a bright white. its not blue. I'd recommend 6000k. they're not hard to swap out the bulbs, BUT MAKE SURE YOU DO IT ON A HOT DRY DAY. (i got condensation in my light unit from when i changed mine and took a LONG time to try to get it out. haha)
14 April 2012
Northampton
I still haven't sorted this, what is the bulb type for our HID's? And what kit are people using for HID sidelights, what bulb type are they?
