slutb8
lookin good but if i got anything to do with the ride height im going to wind them right down while your not looking lol
Along way to go before it's your sister car but mate lol.Looks much better pal
Is that trevor your taking it to?? how much is he charging you if you don't mind me asking?Yeah I see him (WLD99) around quite a bit, don't know who he is though. There's also another pewter S15 on the street next to Blakeney.
BTW, how much ground clearance does your S15 have at the current ride height? I have about 110-115mm clearance but my front pipe is the lowest point of the car at around 80mm. Taking it to CES exhaust for an oval front pipe so it doesn't hang so low.
Have you tried using hose clamps around your exhaust hangers? I did this and was able to pull up the low parts of my exhaust up quite a bit, gained about 30mm in some areas.At present height I'm about the same as you. If I can get my front pipe up 90mm clear I will be happy with that and run the gauntlet so to speak. My middle muffler is also an issue with clearance, looking at getting rid of it for a straight pipe or hotdog but for clearance and a little more sound lol.
You should call in home sometime I'm at the Gabba near Officeworks.
Yeah mate Trevor, just PM'd you.Is that trevor your taking it to?? how much is he charging you if you don't mind me asking?
Yeah ok, I might have a look at that for sure up the back. Dump is bolted up to the factory bracket at the cat so I don't know how I will get around that. Set the height on the passengers side last night and managed to get the dump 90mm clear of the deck, drivers side tonight then fine tune it over the weekend then wheel allignment the following weekend.Have you tried using hose clamps around your exhaust hangers? I did this and was able to pull up the low parts of my exhaust up quite a bit, gained about 30mm in some areas.
