Did you drive it rough? I want to use a stock turbo around 10psi for a daily driver, using side mount, stock exhaust, etc... And a sprung exedy clutch disc (OEM replacement for < 250horsepower). I was hoping the gearbox will last for at least 150,000 miles (over 200,000km)It may help but it won´t avoid...
My 2 boxes failed although using oem dualmass flywheel and ACT sprung clutch disc.
It's not how smooth you shifted, it pushing 350hp through a gearbox that will only tolerate about 290hp at regular track days. Even then they will implode after numerous track events, they are just not cut out for high HP and torque.The gear ratios are not close enough and the input shaft is weak. With a HD organic clutch, around 280hp, high quality gearbox oil and street use they will go the distance.
I run around 345hp and track my car, that is why I got rid of the stock gearbox and put a strengthened Nismo 6 speed in
The C clip will not be an issue if you run a stock car with stock power. I was using Motul gear oil 75w-90w in my stock box without any problems or mishaps..I thought the c-clip could fail at any instant regardless of whether you street it with low power
And what gear oil? I keep reading redline shock proof. What about redline MT-90? Thats what we use in 5-speed sr20 transmissions
Oh, that makes me feel much better. So the gearbox would be ok if I used a stock S15 drivetrain.The C clip will not be an issue if you run a stock car with stock power. I was using Motul gear oil 75w-90w in my stock box without any problems or mishaps..
