clicking sound from engine bay (clutch??)
dns15
before the engine damper i have to purposely slow down my shift when the rev is slightly higher
else itll jus bitch from the gears
i found this problem from 1 to 2 and 2 to 3 most often
i tell u that did not feel good at all
when u have to shift slow as u see the hondas going at the redlines
not like i can lift the engine up anyday tho ..
S15R
true true, 1st - 2nd no problems but 2nd - 3rd i used to have problem with it but got used to it
honda = low torque more traction therefore better launching
:D
S15R
lj~R
the mount on the cross member to hold the gearbox :D
nismo and uras make them
nismo = good
uras = soild-->more vibrations
L
lj~R
got the nismo (3) engine mounts installed today~but the steering wheel seems to be more virvation than before.I know that can be the harder rubber causing that. But it is a bit serious,Especialy on low speed with high rev(3500RPM) anyone think are there anything wrong with steering wheel :confused:
Thanks
Thanks
I get that too with just my engine damper.
Vibrates pretty much on idle.
