Finally went about tackling my no start issue with my S15 Spec-R, after fiddleing about for a while i Noticed the ECM relay (the brown relay located behind the ECU) was not Engaging on its own thus the coilpacks where not getting 12V.
I took the cover off clicked the Relay switch together with my hand and after a few attempts the car started :target:, so at first i though just a bad relay, took the Other brown relay for the Headlights out of the Fusebox under the bonnet, swapped them out but this one didn't click either, tested both for the Headlights and both worked, so this rules out a fault with the relay itself.
so now im wondering what causes the Relay to click over? this is taken from EC81 of the Service manual,
i have a multimeter, have checked values and they are all over the place, anyone know what voltage should be at what pin before i turn the key to crank the car? should they all read 12v? and should the Relay engage when the key is in the "on" position or the "start" position, i assume goign by the Diagram its "on" but just not sure
iv checked Fuses 34 and 35 and they are fine, iv checked both Earths and they are good also,
The Ignition switch pin at the ECU (pin 36) and it is getting 12V at the "on position"
Need some guidance on this hwell:
