Apex intercooler/ Greddy spec-m
3 March 2006
Manchester & London
Thinking about the hotpipe as well. I know that Blitz dump valve comes with a stainless hotpipe, but I heard bad story about having a dump valve thats not recirculated. Is that true? Some sort of air/fuel ratio prob?
What if I can get the car map after fitting the BOV, is that still the case.
The nature of atmospheric BOVs is that they will cause a degree of overfuelling when they dump. This is why people who have them fitted experience more pops, bangs and flames.
Personally, I was more concerned about the awful jerkiness whenever lifting off, particularly at higher speeds. Also, a badly adjusted BOV will cause stalling.
mitch
I have an HKS FMIC and pipes from a 14a. Is the hole in the battery tray in the same place or do the front of the cars have different dimensions? Also, does the washer bottle need tweaking/moving from the original position?
Thanks in advance :)
washer bottle needs "turning" round.
i used the S14 cutting plan for my greddy one... so i'm asuming they're the same.
yea....
hole centre 100mm from right hand side and 120mm from the top as you stand at the front of the car looking into the engine bay.
can't find the picture again, but they're the measurements! :)
