Albert's Nissan Silvia S15 *now with sr20det*
I'm sorry to say that the HKS camp has been discontinued :(
You could do what "PJ" has done and shove a computer in the car.
Then connect the aftermarket ECU of choice and voila. You now got all the info needed on the screen :D
I was thinking about getting a computer in the car before. You get alot of stuff for a good price (navigation, dvd, etc)
But was a little put off when I thought about the booting up procedure :indiff:
S15R
Topper said:
Still available through the website above :thumbs:
yes, the HKS camp has been discontinued and I don't think you can get them anymore but on ebay or Yahoo auction Japan, you probably find them 2nd hand or new on luck
Nicely said:
How do you do that if you've got something like this?
Yoy take a good look at the pics and start to improvise :D
Edit: Or you could start hanging around at Kareoke-bars and try to find a new friend ;)
A
Albert
he-he :thumbs: :D
This night we installed HKS 2530 (Thanks to Chris for turbo :wave: ), outler 3", manifold MeganRacing and a new fuel pump 255h/l. Didn't try what turbo can...becouse it's impossible with our winter =(
The next step: Apexi Power FC and AVC-R...
A
Albert
Apexi Power FC was installed yesterday. But the engine doesn't work correct. I think the trouble is idle sensor...
will see....
Meddy
Have you got the correct injector size and the correct AFM in? Just asking the obvious questions, Im sure youve checked them allready.
A
Albert
I think we made a mistake in wires when we had make changing the engine....Becouse when I make like in Manaul (rtfm....hehe ) about start w/o A/C and e.c. all is ok...
but when I make the next start of engine the problem came again... :(
A
Albert
Installed exhaust KAKIMOTO Racing and BOV HKS SQV....
But until the problem with IDLE..... I think need to check ECU harness
A
Albert
For a long time did not write here. Actually here so now all looks:
I tune my PFC for 1.2-1.3Bar
Here is my Apexi Power FC map: http://nismo-club.ru/albert/albert.xls
And now the plans for winter:
engine:
- JE pistons 86.5mm
- Brian Crower S13 SR20DET Camshafts 264/264
- Brian Crower SR20DET Valve Spring + Retainer Kit
- Greddy Metal Head Gasket SR20DET 1.2mm
- Greddy SR20DET Oil Pan
- Eagle Rods SR20
- OEM bearings Crank/Rods + WPC
- S13 SR20DET Engine Gasket Kit
- ARP headstud kit sr20det
- Megan Racing pulley
- PE belts 3pc kit for S13 with AC
- Tomei Rocker Arm Stoppers
- Circuit Sports S13 sr20det Turbo Lines (Bottom mount)
- GT Oil Drain Kit
- HKS 2540 / HKS GT-RS (???)
transmission:
- ??? Short Shifter
- NISMO Slave cylinder
- NISMO Pivot
suspension:
- Battle Version Rear Upper Control Arm
- Tein Adjustable Hard Tie Rods + Tierod Dust Boot
- ??? Tension Rods
- Tanabe Sustec Sway Bars (Drift Spec)
to be continued... :wave:
A
Albert
Yakozan said:
Looks like you have alot to do this winter :)
we just got snow over here in Stockholm :(
yep... all things was ordered so will be waiting... :D
There are snow in Moscow too ;-) So my baby is in garage and waiting for tune :D
There are two position in this tune list:
nobody knows how is it? Becouse the price is nice but nobody knows is it good or not .
