Swapped a sr20det into my spec s last year and didnt fill the ac gas until now.
The issue now is that the ac starts a few seconds before it stops and it does this two times before not working at all. I can se it clutches in and then stops.
Should be enough gas and no leaks, but not 100% sure.
Tested the climate controlled with no issues. Is there any hidden wires or relays that might need a check or should I replace my compressor?
