Hey mate, i increased the valve size to get more flow from the head ( as the head was off it seemed a good idea to just do everything i can at the time).... im not sure what your tuner means by fly by gas, if he is meaning valve overlap where the exhaust valve opens during the same time the intake valve does, then that is a cam timing issue and should be timmed back up again. The hole reason for the port,polish,cams, bigger valves ect... is to gain more flow, a good way to make more power is by increasing flow either by force ( upping the boost) or by natural mechanical flow.hi there guest_jdm, can i check why you increased the size of the valves, is it the port and polish thats why you have up by 1mm? I just sent my car for mapping and was told the the fly by gas is too high to tune properly.
this fly by gas i think meaning not reaching the compression needed. I got the parts all standard sized, and the garage i went to ported and polised the head.
So i suppose i should upsize the pistons and valves too? not sure if this makes sense.
:nod: Just put the pistons at TDC, I had cams changed on my SR without having to fill the bores with compressed airYou can probably put each cylinder on top dead center and then pressurise the cylinder with compressed air.
This would be done by taking the spark plug out and screwing an adaptor in to hook up an airline. This should hold the valves shut.
