Yeah, so i've got a coolant leak, that only happens sometimes, and in varying quantities. VERY CONFUSED.
i first noticed it a week ago when my reservoir was near enough empty, so i topped it up. and then a few days ago it dropped by about 1cm, so i topped it up.
and then again today i saw the fluid on the floor in a small puddle, (probs only 1cm of the reservoir again). cant work out where the leak is til i get it on ramps, but looks near the bottom of the rad.
Either way, why would it only leak sometimes? could it be to do with the amount of coolant inside the reservoir?
I've got an aftermarket Japspeed rad (50mm) and as a result i fill the standard reservoir a bit over the standard markings. Is this ok?
I'l update when i get under the car and find the source.
Cheers
Cheers
