There aren't too many Autechs around so there's even less info on them than the Spec S :wack:
Intake is already bigger on the Spec S so I'd imagine it's the same on the Autech but I don't know. Bigger injectors, fuel pump & possibly a Z32 AFM should give a bit of an increase but again I don't know if the injectors / pump are closer in size to the tiny spec S ones or the larger spec R ones...
Lightweight pullies should increase you're throttle response...
Are you looking for a fast road car, track car or something for a bit of Dori?? My spec S got a lot quicker around the track with upgraded suspension / chasis / braking components
Edit - not many answers here;
The Autech model runs the Spec S SR20DE engine however it has been moddified by Autech to produce an additional 35hp through the use of a different ECU tune, extractors, higher lift and duration cam shafts, sodium filled exhaust valves, higher compression ratio and a lighter flywheel.
Unsure of Autech Injectors, probably standard SR20DE. The 370cc injectors are purple in colour, the 480cc injectors are a dark red maroon colour
Unsure if Autech has a different pump from standard SR20DE
http://nissans15.com/spec.htm
So, what colour are your injectors???
