tripleJs15
Lots of truth here, I had a friend that went from a 86 to 86.5 to 87 without sleeves, anything over 87 you should sleeve, for the HP goals you're shooting for you will be just fine without sleeves.86.5mm-87mm pistons are mainly regarded for use without sleves dude but if you do 87mm then score the bore your only other option is either sleave it with larger pistons or start again with a fresh lump
mind you a big end blown sr20det can be picked up for peanuts
i personally wouldnt bother buying turbo and injectors simply because if you spend a few months/ years building a engine that can take 500-600bhp or more i doubt you would use such a small turbo (its kind of a waste using a gt2871r on a forged or stroked sr in my eyes)
get yourself a engine build book for some toilet reading and a sr20det to rip appart
then go from there
A decent build i.e:
On the GT2871r 56trim 64 a/r, US 1,000
cams (264 or 260), US Tomei 500
cp pistons 86.5 (i used 9:1 CR) US 500
ARP head, main and rod hardware US 200
valve springs (not really required but a good idea, some Brian Crower's will get the job done, US 75
rocker arms stops US 100
MLS headgasket (Coswroth, APEXI, PE, even cometic) US 100 - 150
and a good tune will get you to 400 or slightly over.
I've made 384whp using 93 octane on a dyno dynamics, which is slightly over 400hp on a dyno jet with the above setup.
