tooley
When only sideways will do!
10 October 2009
West Midlands / South Wales
:thumbs:
***Spec updated for 2015***
Body
Vertex Front Bumper
Dmax +50mm front wings
Dmax + 30mm Rear Wings
Dmax Roof Spoiler
Dmax Duck Tail Wing
Dmax Side Skirts
Trial rear bumper
Gusseted 16 point welded roll cage
Dmax Rear Lights
Tubbed Front Arches
Tubbed Rear Arches
Engine:
SR20DET S15
GT28R turbo
Branch exhaust manifold
Uprated Cams
Japspeed Turbo elbow
Japspeed Down pipe
Japspeed De-cat pipe
HKS Cat back system
Autobahn 888 Front mount intercooler
Walbro fuel pump
Blitz duel spec II boost controller @ 1.0 bar
Apexi power intake filter
HKS SSQV
3" ally rad
Apexi Power FC / Commander
Mocal Oil cooler
Powertrain
ORC Twin plate clutch and lightend flywheel
OS Giken 2-way LSD
Poly Gear Box Mounts
Poly Engine Mounts
Metal Diff/Fram Bushes
Suspension and brakes
PSM Pro Knuckles Front and Rear
Driftworks CS2 Coilovers
Modified Steering Rack
Lengthened Steering Arms
Lengthened lower arms
Full Adjustable arms
Interior
Zillalife Glitter Back Bucket Seats
Zillalife Deathtune Gear Knob
Hydraulic Handbrake
Deep dish Wheel
Boost, Oil Temp, Pressure, Water Temp.
Safety
Twin Zone Fire Extinguisher
Hand held Fire Extinguisher
Pull chords on Scuttle Panel and Dash
Dry Cell Battery in Cabin
ITS STILL IN BITS :(
Roll back to the sart when i was a noob s15 owner
nice car mate - welcome:D
....but.....i cant agree on the advans as i've never been a fan but its a personal taste thing - if you like it then cool.
are you sure its an 02 and wasnt registered wrong? only ask because i think uk importers cant bring in cars newer than an 01 due to not having a model report or something like that?
tooley
10 October 2009
It is a 2002 everything is dated all the documents and even some of the compenents on the car. If its not then ill have to get the v5 changed since if its a 2001 then i can be on the cheaper tax band!!
I have been looking at thoes whees!!! they are awesome and a dam site cheaper than the rota's!!
seeing them on the 15 has twisted my arm!!!
Trial_S15
13 July 2008
Meath, Ireland
www.modifiedmotors.ie
Where are you finding genuine TE37's cheaper than Rota GTR's??? Both would look fantastic on you car in white but the TE37's would definately be my choice if I had the funds....
About €1,700.00 for a set, not including tyres or delivery :cry:
http://www.nengun.com/rays-engineering/volk-racing-te37
You should be able to find some decent second hand ones for Rota money though :thumbs:
tooley
10 October 2009
ahh wait there are copies made by invoite look slightly different to the TE37's
eeeeek thats alot!!! will have to brows
tooley
10 October 2009
Fitted my FMIC and Walbro today! :D:D
Was dark when i was done so got no pics of the finished work will post 2moz.
Is the standard fuel pump ment to be that small? since usually the walbro is smaller than the OEM???
Yeh, thats right. When I fitted mine I used the foam insualtion that comes in the kit as it held it in the OEM bracket properly with the cable tie.
30 December 2008
Essex
Import rules have changed now. You can bring pretty much any car into the UK since.. i think April?
They did away with the model report and ESVA.. its changed to IVA now i think, its alot easier to pass, this also means you can bring modified examples in, whereas before you were limited to standard examples
www.torque-imports.co.uk have 2002 spec r's and Spec S's now just to confirm.
Also, cery nice car dude, can't say i'm loving the Advan's but it'll look alot better once it's closer to the floor
:D
Sender
7 June 2008
Poland
Yep, get it closer to the ground.
I know what I'm saying, used to have advans on my S15 :nod:
tooley
10 October 2009
Yep coilovers are on the next list, what is every one using?
Tien
KI office
HSD
Drift works own
Ksport
Not sure what to get
sx-si
7 June 2008
hampshire uk
in my experiance my list would be (best first)
jic magic
cusco
tein
dw cs1
hsd's
apparently bc racing are good too but not used them
ki office and k-sport i woul;dnt touch with a barge pole
general rule of thumb is you get what you pay for
but alot of people are liking the hsd's due to there price
i personally go a step higher so cs2 or better
then it comes to spring rates and what you want to use the coilovers forsuch as
track only -- tein
drift only -- cs2 DW
fast road only --hsd with lower spring rate
these two depends on how much you can bare
fast road and compeating
fast rode and the occasional track or drift day
then i would go for tein cs2 or cusco's because i think its worth the hassle but you could get away with some comfy hsd's if youy dont go track very oftern
so the choice is up to you
and this is my experiance from s14a's and other 200sx's
tooley
10 October 2009
Well i have two front Ki office coilovers on my sr20det powerd rx7, the build quallity is awesome on them but they are very hard!!!
Been looking at the ones on DW they seem ok!
Tein Super Streets are superb value for money - you should be able to pick these up for around £850 - £900. Got mine from Camskill Performance as they were the cheapest but had to wait a couple of months on delivery. S15 suspension from Japan is rarely in stock so that's also another reason why I guess CS2 and HSD items are popular!!
I've only heard good things about BC Racing suspension so maybe worth a look at these :)
The spring rates for Tein Super Streets are excellent for fast road - still able to take a few bumps at speed and generally a pretty comfortable ride (although the wife completely disagrees lol)... I've taken it out on track and they're good but I can imagine the Tein Flex system giving you that much more... it's a compromise between road and track at the end of the day.
James
