sillbeers15
I've been doing some research on my own after reading the article posted by Nicely about the unsuitability of HID conversion kits.
As our S15 headlamps come with projector lamp for lowbeam regardless wether it were HIDs or Halogen.
I have been trying to understand their differences and I think I have cracked the nut.
There is no magic in projectors suitable for HID bulbs. Inside any projector unit, there are the following:
1. Lens
2. shield (steped edged if beam pattern shows such)
3. Reflector
The only difference a HID bulb will create from pluging it directly into the holder of a Halogen projector is the position of illumination. What I mean is if you place a H1 bulb side by side with a D2S HID buld retrofitted for H1 application, the HID bulb is much longer. If you look carefully, you can find both illumination point of both HID and Halogen bulb.
There is a rather simple solution to make the retrofit work perfectly.
That is to compare and determine the step back required for the HID conversion bulb and slot in high temperature rubber washers to compensate the differential distance. Also find a way to preperly secure the HID conversion bulb now that it is protruding more out of the projetor housing.
I am certain this will create the correct beam pattern that meets test standards after correct focul point has been acheived.
I'll do the test myself and show the results later.
If any kind soul is willing to try it out and post the results before me is welcome.
1. Lens
3. Reflector
