Pazz
Greater pressure from turbo at higher revs will overcome the leak. (to a certain extent)If it was a leak, why would the boost dip off then rise again?
I think he uses them as curb feelers so he doesn't hit his exhaust :rotfl:WTF is those cable ties for? Fluro too -_-"
Isn't that going to require a band expander?-Kenwood Double Din Headunit
Well Torque must of wired it up through the OEM Cables as it was a case of plug and play and it all works grandIsn't that going to require a band expander?
Looks good. Except for the stupid cable ties, of course. Hopefully you'll get some coilovers next so that you can remove the 4x4 mod...
Nicely the answer is no you can't... JDM radio signal will top out around 92-93 but I guess it doesn't matter if you don't listen to the radio.Can you pickup 88-108MHz on FM radio? Or don't you ever listen to radio?
absolutly, Yeah the deer went under instead of over so i was lucky to say the least, Poor deer didnt come out so well tho Felt like a tool afterwards but not much i could have done to be honest.I was expecting a lot more damage... your lucky it wasn't worse. But it still sucks that it happened.
