Locking wheel nuts
Darren_S15
Club Event Orgainser
18 January 2008
Essex, UK
I have no idea which locking wheel nuts I need for an S15.
Can someone point me in the direction of a fairly decent set of them.
Maybe McGuard ones or something...
Web link would be much appreciated.
Thanks a lot,
Darren
You need ones which fit Nissans ;) :p
McGuards are the best IMO, but they require quite big holes surrounding the wheel nut to get their adapter to clear. I can't fit them to my alloys because of this :( And I know quite a few other alloys they wouldn't fit either. I had to go for for a set which have three ins in the key as they were the only ones I could get at the time. They are a right b@stard if you do them up too tight. The pins in the key tend to shear quite easily...
These look OK :)
Iv'e got Ray's locking nuts on mine and the special key is easy to use as they have a tonge and groove set up so you get good purchase when you undo/tighten them up:D
Darren_S15
18 January 2008
Essex, UK
Thanks Nicley.
They look like they will do the trick :)
Ill have a look at my clearance around the nut tonight and if its large Ill get the McGuard, otherwise Ill play safe and get the Kosei one.
Darren_S15
18 January 2008
Essex, UK
Just for the record I ended up getting McGard 25254SU
They are M12 x 1.25.
Fit like a glove :)
Thanks for the help guys :thumbs:
