Darren_S15
Club Event Orgainser
Would you need to remove the plastic from the light unit to get rid of the yellow tint, or just rub down the outside of the plastic on the headlight?
Thanks,
Darren
Thanks,
Darren
The stock H4 bulb has 3 wire connections. A low, a high and a earth, correct?--------------------------------------------------------------------------------
I fitted an uprated loom to supply the HIDs with power direct from the battery. This is recommended to protect the original loom from the increased current during HID ignition. I also have a relay kit fitted which separates the HIDs from the high beams and keeps them on constantly, regardless of whether you engage high beams or not. The HIDs will not ignite if you 'flash' your lights during the day either - just the highs.
----Nicely
If it an't any brighter than H4 Halogen bulb, ....why do the HID conversion? There are many 'white' H4 bulbs available in the market.--------------------------------------------------------------------------------
4700k are about the same as most OEM HIDS and are a pure white. I have 6000k fitted, which give a bluer tint. Any higher or lower than these two temp ratings is actually counter-productive. They may look cool, but the brightness of the light produced is worse than ----Nicely
Gosh Nicely,Took a while to find the diagram I was after. I've now hosted it myself as I keep having to look for it periodically.
An SXOC member originally made the relay kits but became a little bit unreliable when people asked him about making more of them the other year. He also wouldn't give a wiring diagram for the kit, so I ripped the back off the relay box and drew a VERY basic diagram. Its NOT meant to be a wiring diagram, only to show what's what.
I did have the rating of the capacitor somewhere, but I can't find it...
Here's the original diagram showing how to wire the kits:
So the negative from the Ignitor goes to the original negative from the headlight plug, and the positive from the ignitor to the red wire from the "box o'tricks", where does the positive from the headlight plug go? Does it conect to the ignitor via the white wire?Here's the original diagram showing how to wire the kits:
I would say leave them as is.What about the Earth of the sidelights?
