mint
- 18 March 2007
- Age
- 38
- Asakusa, Tokyo
- www.JDMtas.com
Alrighty Folks.
Ok when the car got ported over i got Torque to install an Alarm system for me, i got the Cobra system (iirc, I'll double check..) Anyways been working a treat however last week (When it was hella cold) when i went to open the pass door it opened onto the latch and got stuck..
I pushed it closed and it would open correctly, Turned out everytime i locked the car all doors would lock fine but when i unlocked it the passanger door did it again.. time after time wouldnt open when you went for the handle, i sprayed some WD40 inside the door latch bit and it worked.
Now a week passed (Still with this problem) iv noticed that when i unlock the car (Including using the button on the driver door) the inside manual lock only opens half way if you know what i mean, thus the only way to let a passanger in is to reach over (inside) and open the lock before the door can be opened, obivously a bit of a hassle with a set of tight takata's..
any advice folk? Anyone else had this sorta lock/latch problem with the pass side door? Oh also using the key on the pass door still dosnt open the lock. it used to..
Cheers Lads
-Minty San
Cheers Lads
-Minty San
