My daily pearl white
bzh kevin
22 September 2015
bedford
New headgasket, headstuds, vtc cam sprocket and various engine bits have arrived .
Cleaned bits ready to be fitted back along the new parts .
bzh kevin
22 September 2015
bedford
The shell should be going to the paint shop this week . As I wanted to retain all the OEM panels, it was decided that the bonnet, boot lead and doors will get an acid and E-coating treatment to get rid of all the rust and hopefully cut some of the prep time for the painter .
PREPAINT_SHELL_1.jpgPREPAINT_SHELL_2.jpgPREPAINT_SHELL_3.jpgPREPAINT_SHELL_4.jpgPREPAINT_SHELL_7.jpgPREPAINT_SHELL_6.jpgPREPAINT_SHELL_5.jpg
bzh kevin
22 September 2015
bedford
the shell is now with the paint shop, in the meantime HTDevelopments is still working on the engine . It's coming along nicely and will be looking as fresh as it can!
The sump is pretty was pretty heavily corroded and will be replaced by a Greddy high capacity sump before the car leave the shop .
EngineRebuild_4.jpgEngineRebuild_5.jpgEngineRebuild_6.jpgEngineRebuild_7.jpgEngineRebuild_8.jpgEngineRebuild_9.jpg
bzh kevin
22 September 2015
bedford
To get the exact details of the process and product used, it would probably be better to ask them directly .
but as far as I understand :
- First the panels spot welds are drilled to expose the panel seams or to remove the panel completely.
- They grind(sand blast for the front panel) cut and reweld panel where necessary to remove all the rust .
- Once the rust is out of the panel, it gets rust converted to make sure everything is completely gone .
- The panel is then primed and welded back in place .
- Once all panels got cleaned and back on the car, the shell was pumped with an epoxy coating until it oozed out of every seams to make sure all the panels inner are covered and sealed .
- seam sealant is then applied and the shell sent for paint .
bzh kevin
22 September 2015
bedford
The car is still at the paint shop but now down to bare metal . The filler used to 'repair' the previous rear quarter panel damages have been removed and the panel straighten properly .
28 May 2023
UK
Plenty has happened in the last few month . The car goes to paint in August, the engine bay is getting the last few touches and sealer before .
View attachment 2565View attachment 2563
In the meantime I got the once in a lifetime opportunity to work in Japan for 2 years . One thing leading to another, I now own a chaser at Ebisu 😅 .
View attachment 2566View attachment 2567
What do you do for a living? 😅... And what wide arch kit does that chaser have, that's so clean!?
bzh kevin
22 September 2015
bedford
To be fair I don’t know much about body kits but after a bit of googling the kit is probably a ito auto V1 kit .
The car is slowly turning into a missile so the kit probably won’t last forever .
I work as a 3D modeler for Nissan design Europe in London . It’s pretty common for Japanese multinationals to offer the possibility for employees to transfer between different production sites . I couldn’t refuse when the offer came around!!
