Hello guys i need help you guys identify my car, its model is GBYARUAS15U4E--A- does my car have Helical or Viscous LSD or Open differential?
Thanks
Thanks
SR20DET Spec R Automaticwhats the engine number on the the vin plate in the engine bay if its an sr20det then its 3.9 helical and it its sr20de then its an open 4.1 diff
I'm going to replace differential oil but still not sure to use differential oil or lsd oilah its an auto, I think they are 3.9 viscous diff
Thanks sir, will open later when i reach home and get check it using notebook because i cant open it thru android smartphonehere is al link to the service manual S15 Service Manual
Sir i only can find it say differential use GL5 so now still cant decide to use what differential oil either LSD or basic differential oil because i'm worry if put wrong oil that can kill my car differentialhere is al link to the service manual S15 Service Manual
Thanks a lot SniffyS15: 1.2-1.4L (80W-90 API GL-5 gear oil) (Use regular differential gear oil, not oil designed for LSD differentials)
S13/S14/S15/Z32 Fluid grades & quantities - Silvia Technical Articles - Hardtuned.net
Hello again sniffy, just want to ask if i can use s14 lowered coil spring on s15? I cant find any for s15 here. Its H&R lowered springNo problem Dude hope you get her sorted
