Suspension Setup
19 June 2016
Midlands
Hi all,
Just posted another thread (https://forum.s15oc.com/mechanical-and-bodywork/16280-wheel-fitment.html#post158061) about wheel fitment and now Im looking to do the suspension at the same time due to wanting to run 18s hence looking to lower the car by around 25-35mm.
I gather i cant do this to the stock suspension without knackering it so need some advice/discussion on coilovers.
Im going to use the car as a daily so need something thats not too harsh but will allow me to drop the car a touch and maintain good handling characteristics. any thoughts on a good setup? what are you guys running?
ive looked at a range of BC's, Teins etc and can see how they are rated but wanted some input on real-world performance on the street. not looking to track my S15 much if at all so just need a good street setup.
cheers for any answers!
Shifty.
21 July 2008
Essex/London
Have you considered Nismo s-tune?
If you see only dropping it that much and it's street car only it may be more suited to your needs.
You have picked two suspension brands which will pretty much serve the needs you have described..I would pick the Teins over the BC's for quality and I reckon the Tein Super Streets would be ideal for what you have described
20 November 2013
Essex
i wouldn't touch Teins with a barge pole, the top mounts on mine literally crumbled away, when i spoke to Tein UK (granted universally known for being absolutely crap, they simply didn't want to know)..the suspension was 4 years old at the time)
19 June 2016
Midlands
thanks guys. i havent looked into Nismo S-tune yet so will do now. Super Streets were on my list of suitable candidates but ive heard some mixed reviews on them so will investigate more. is 25-35mm drop the right territory to suit an 18 wheel? im not looking to slam the car as i want to maintain clearance for daily drive practicality but i do really want 18s and stock ride height makes them look a bit waffy i am told.
Edit: Tein review case in point it seems. thats a naff failure right there. what do you run now mr janus?
20 November 2013
Essex
i now have HSD TT's (which have now been discontinued) but been on the car for around 5 -ish years, and they look and perform fine.
20 November 2013
Essex
the MonoPro are much better than mine, the TT's were entry level and priced accordingly but yeah i don't really think you can go far wrong with HSD's
19 June 2016
Midlands
thanks. been looking at more threads on spring rates too. would 7/5 be too harsh for street? or does this depend more on the damper? 6/4 seems preferred for street from my research.
are coilovers a better option than getting seperate springs and dampers?
will a coilover take up more space towards the wheel hub ergo reducing wheel width allowed?
thanks again :) this forum is awesome.
20 November 2013
Essex
coilers are the way forward, you have so much more control over the damping/rebound and camber settings when used with adjustable top mounts etc.
as for fitment, the shock itself tends to be narrower and less bulky and doesn't have the lower platform where a spring would sit so fitment of larger wider wheels is generally easier
19 June 2016
Midlands
awesome; thanks man. will do some more reading in to the various brands but those HSD's are a good front runner
Check out meister r as well around that price , better quality than the hsd
19 May 2015
Yeah the Meister R are pretty decent, I got all 4 for 700quid. Thought that was a decent price point too. Believe they are 8kg rears and 6kg fronts. Ride is stiff but not uncomfortable.
Sent from my PLUS using Tapatalk
I think most manufacturers recommend 8/6 for our cars
4 August 2011
8/6 is still pretty firm for the road. 6/4 would be better imo. Bc coilovers ar meant to be good for the cash. apex gen 2 coilovers are essentially the same and you could spec a "comfy" variant which is well suited to the road.
tein are meant to be good but don't suit the uk very well.
Iv'e never seen a camber top so seriously corroded as that...was that salt ?
21 October 2014
Staffordshire
The only input I can give is that I have the BC's and they feel way too hard on even the softest damper settings. I don't know if the pre-load on the spring has been altered on mine, as I didn't fit them, but I suspect they're how they came out of the box.
CMR
22 August 2011
Yorkshire, UK
I've been on the fence about meister-r for the S body's for awhile. I had them on my mx5 and they were amazing but no one seems to buy them for s bod's.
Or if they do no one ever posts reviews lol.
Ha ha I think more likely the latter dude , I know a couple of people who run them and are impressed with them
